basysaz
Dec 11, 2019Tutor
Recovering Admin PW - OS Reinstall doesn't work
My RN312 with two 4TB drives in RAID-1 and running OS 6.9.1 is working OK on my LAN. NAS volumes mount on both Mac (macOS 10.13.6) and Windows 10 Pro (1903) and operate nominally. But I've mispl...
basysaz
Dec 12, 2019Tutor
Thanks for the replies.
StephenB IIRC, I used the forced-shutdown (hold power button for 5+ seconds) not the graceful shutdown (press power button twice) described on p. 65 of the hardware manual, resulting in the 48+ hour file system check as reported by the RAIDar app, which I interrupted by anther forced shutdown to resume nominal use. I'll try again using graceful shutdown before OS reinstall and report results. (I did read the harware manual to determine how to initiate OS reinstall from the boot menu but overlooked the shutdown procedures. Once again, the old adage holds: when in doubt, RTFM - fully!)
Sandshark Because I couldn't log in as admin I didn't have access to the dashboard or any diagnostices showing the status of an OS partition. The external backup size ws 607 GB and mounting a NAS volume reports 3.27 TB free, though that's probably data outside the OS partition.
basysaz
Dec 13, 2019Tutor
SUCCESS!
I used the preferred (graceful) shutdown procedure from the RN312 hardware manual, then selected the OS reinstall option and rebooted the NAS. Took a few minutes and came up with default admin UID and PW, on a new IP address (had been using fixed IP). Login worked fine, and a prompt to upgrade from OS 6.9.1 to 6.10.2 appeared, which I did.
Manually mounting volumes on the new IP worked OK, no appparent data loss. The whole process took about 30 minutes, including OS update. StephenB and Sandshark, thanks for your help.
- Jul 15, 2018Retired_Member
