Gary86
Jun 12, 2020Follower
recovering files- dosattrib
hi I have an RND2110 v2 which has given many years of trusty service. But, now it's failed, it's a power issue- started by failing to boot up in the morning (I had it set to turn off overnight) a c...
- Jun 12, 2020
Those files store the Windows file permissions for the main file. I do suggest getting rid of them.
After you restore everything, you should be able to search for all *.dosattrib using the file explorer search bar, select all the files with cntl-a, and then delete them all by pressing the delete key.
Jun 12, 2020Guru - Experienced User
