JovannB
May 19, 2017Tutor
reestablishing SMB-Connections lasts up to 30 minutes
Hi, I've a 314 NAS (mounted as drive M:\) behind a HP-Procurve-Switch, for some reasons (ransomwareprotection) I disconnect that certain switch port by snmp-command - thats no problem. Later the...
- Jun 13, 2017
Hi,
I installed the latest Firmeware (6.7.4.) on my NAS some days ago and now I thought to test whether something has changed relating to my problem.
Indeed, when I disable my Switch-Port (where NAS is connected to) and then (re-) enable that Switch-Port (HP-Procurve-Switch, disabling/enabling via SNMP-Command) then it lasts 10 seconds!!!! until I have a SMB-Connection to my NAS.
Amazing, thank you for your effort spent in my case.
J.B.
mdgm-ntgr
May 19, 2017NETGEAR Employee Retired
Odd. Can you reproduce the issue then send in your logs (see the Sending Logs link in my sig)?
- JovannBMay 19, 2017Tutor
Hi,
as far as I can see in the logs there is nothing in particular - I jotted the time down when I did my tests 10:32 and at that time there no log-entries
Is there a deeper inview into the logs ??
Where to upload or sent the logs too ??
J.B.
