JovannB
May 19, 2017Tutor
reestablishing SMB-Connections lasts up to 30 minutes
Hi, I've a 314 NAS (mounted as drive M:\) behind a HP-Procurve-Switch, for some reasons (ransomwareprotection) I disconnect that certain switch port by snmp-command - thats no problem. Later the...
- Jun 13, 2017
Hi,
I installed the latest Firmeware (6.7.4.) on my NAS some days ago and now I thought to test whether something has changed relating to my problem.
Indeed, when I disable my Switch-Port (where NAS is connected to) and then (re-) enable that Switch-Port (HP-Procurve-Switch, disabling/enabling via SNMP-Command) then it lasts 10 seconds!!!! until I have a SMB-Connection to my NAS.
Amazing, thank you for your effort spent in my case.
J.B.
JovannB
May 23, 2017Tutor
Hi,
I've only one 314-NAs, can someone out there try if it is possible to replicate my problem ??
Delay of possibility to establish SMB-Connection after disconnection/reconnection of ethernet or after rebooting the NAS.
J.M.
JovannB
Jun 13, 2017Tutor
Hi,
J.B.
