SERPCOM
Oct 30, 2022Aspirant
Remote Backup using Apple Time Machine ReadyNAS 426 (2x2TB Enterprise) (RN426E22) 511174EE00125 VPN?
I want to access my Apple time machine on my MacBook to remotely back up from home. In the office on the same network time machine works great. Also is it possible to access the admin page re...
Jan 28, 2023Guru - Experienced User
The ReadyCloud service will be ended soon anyway, so there isn't much point in pursuing issues with it now.
jbattista
Jan 28, 2023Tutor
What have you heard? Is Netgear just going to "brick" this device for a desktop paperweight? Is there another software that will sync with it?
- StephenBJan 28, 2023Guru - Experienced User
https://kb.netgear.com/000065438/Support-for-ReadyCLOUD-feature-ends-spring-2023
Note that they are not saying that Time Machine won't work, just that remote access and other services provided by ReadyCloud will end.
There are alternative means for remote access. For instance, other VPNs (including OpenVPN built into Nighthawk and Orbi routers). Zerotier can also be used for remote access (and can be installed on the NAS).
