Jun 12, 2014Aspirant
Remote UPS - Shutdown
I am using a UPS APC Back-UPS ES 700VA connected to another device using a USB cable. This device by using the remote ups option of ReadyNAS RN10400 sends the state of the UPS to ReadyNAS. When the el...
03397
mdgm wrote: Is the power cable for your router/switch also connected to the UPS. The NASes need to be able to communicate over your network when the power goes out.
Yes it is.
Like I told you the event when the ups kicks in can be seen in readyNAS. So, I am pretty sure that the readynAS knows that runs on UPS so QNAP send the event to readynas
