Jun 12, 2014Aspirant
Remote UPS - Shutdown
I am using a UPS APC Back-UPS ES 700VA connected to another device using a USB cable. This device by using the remote ups option of ReadyNAS RN10400 sends the state of the UPS to ReadyNAS. When the el...
mdgm-ntgr
Jun 12, 2014NETGEAR Employee Retired
It sounds like the QNAP is powering off before telling the ReadyNAS too.
What difference does it make if you increase the number of minutes or change to using the "Turn of the server after the AC power fails for" option. I don't think the ReadyNAS has the "auto-protection" mode so configuring the QNAP to use that could be the problem.
