nilsson_lina
Jun 30, 2022Aspirant
remove inactive disk and possibly a bad disk
Good day, I have a messy issue with a lot of uncertainty and forgotten facts because this happened over a year ago and I'm now trying to recover my data. I have a ReadyNAS, RNDU4000. Firmware 6.10.5...
nilsson_lina
I've been trying to reach the support for a few weeks without success. So my best options seams to be to do it myself.
A question to your suggestion
StephenB wrote:If you want to try that on your own, you'd need a way to connect the disks to a Windows PC and try ReclaiMe software
( https://www.reclaime.com/ ) or other RAID recovery software that supports BTRFS.
Are there any tool that can recover directly from the NAS thought the network, so I don't have to connect the disks individually to my computer. I only have one SATA/USB connector available at the moment and I guess would be good to let the recovery program have access to all 3 drives when it's doing its magic.... just guessing though.
Many thanks
Jun 30, 2022Guru - Experienced User
You'd need to get suitable adapter/docks, so you can connect all three drives. There are some that handle multiple drives. Prices vary, but you can find 4 bay enclosures for about $125 USD.
