R_W
Mar 21, 2019Aspirant
Remove inactive volume to use the disk - error msg rcvd after replacing bad disk with a new disk
I replaced bad disk in slot 2 with a new one. Booted up RN214-4. Error msg says to delete inactive volume on disk 2 to use it. Did that, twice. System still shows same inactive volume error. And...
- Mar 22, 2019
R_W wrote:
Formatted
Then normally you need to select the disk on the volume page, and then click on format again. The NAS won't automatically add a formatted disk to the array.
Though another option (IMO better) is to connect the disk to a Windows PC (USB or SATA) and test it with vendor tools (Seatools for Seagate; Lifeguard for Western Digital). If the non-destructive long test passes, then run the destructive write-zeros test. That will unformat the drive, and also gives some confidence that the disk is in good shape.
R_W
I'm trying to get the system to acknowledge the new disk in slot 2 and add that new disk to the existing X-RAID (RAID 1).
- StephenBMar 21, 2019Guru - Experienced User
Was the replacement disk blank? Or was it formatted?
- R_WMar 21, 2019Aspirant
Formatted
- StephenBMar 22, 2019Guru - Experienced User
R_W wrote:
Formatted
