Aner2313
Jan 18, 2023Aspirant
Remove inactive volumes to use the disk #1-2-3
Please anyboady help Ihave READY NAS server RN2120 and massege (remove inactive volume to use the desk #1-2-3) I search about solution and i find reply that i need to use command ( btrfs rescue) b...
Jan 19, 2023Guru - Experienced User
Aner2313 wrote:
I search about solution and i find reply that i need to use command ( btrfs rescue) but i run it with windows 10
Note : the issue happened case of disconnect the power or remove the desk once the server is running )
Then you likely need to forcibly assemble the RAID array with mdadm (and not use btrfs rescue).
You'd need to enable ssh on the NAS, and then access the NAS by entering ssh root@nas-ip-address in the windows search bar on the NAS. Do you have any experience with the windows command line?
Aner2313
Jan 19, 2023Aspirant
No i dont have please give me step by step how to do it through cmd
By the way today i try to access nas server but the ip is not bing and i cant acccess to nas if u face this issue please advice
- StephenBJan 28, 2023Guru - Experienced User
By the way today i try to access nas server but the ip is not bing and i cant acccess to nas if u face this issue please adviceSorry for the late reply.
Are you still unable to ping the NAS on your network?
