shafy
Mar 09, 2019Aspirant
Remove inactive volumes to use the disk. Disk 1,2,3
Hello,
I'm having this issue Remove Inactive Volumes 1.2,3,
the only option is to format. is there a way to fix.
Hopchen
Mar 09, 2019Prodigy
Hi shafy
Sounds like either raid or filesystem might have troubles here.
Did you do anything prior to this happening? Replace disks or anything like that? Or did it just happen "out of the blue"?
Mar 09, 2019Guru - Experienced User
There are multiple causes here, so the best way to resolve it w/o a factory reset is to contact paid support.
If you have the linux skills, you could sort out whether the problem is related to RAID or the file system via the linux cli.
- HopchenMar 09, 2019Prodigy
I can take a look at the logs as well if you like.
You could download them from the NAS and upload via Google link (or similar) and PM me.
