AHPL
May 20, 2022Aspirant
Remove inactive volumes to use the disk
I have Netgear readyness 428. From last few days it is showing remove inactive volume 123456 to use the disk, Netgear technical team not giving any support because product is no longer supported. Ther...
May 20, 2022Guru - Experienced User
Something odd there - did you purchase a support contract? Perhaps the mods ( JeraldM or Marc_V ) can help with that aspect.
AHPL wrote:
There is 14 TB important data of last 5 years in the drives and I don't have backup.
Ouch.
Have you downloaded the full log zip? Did Netgear support do any troubleshooting?
- AHPLMay 20, 2022Aspirant
Sir,
I have purchased a support card, and during activation of the key, a message shows the key is not supported for this product. After that I sent a mail to the Netgear team but no benefit I am helpless.
I have already downloaded the full logs.
- StephenBMay 21, 2022Guru - Experienced User
AHPL wrote:I have purchased a support card, and during activation of the key, a message shows the key is not supported for this product.
I suggest also sending a private message (PM) to Marc_V with the details of exactly what you purchased - he might be able to help with support access. Send a PM using the envelope icon in the upper right of the forum page.
Netgear doesn't offer support for used ReadyNAS, so you do need to be the original purchaser.
