AHPL
May 20, 2022Aspirant
Remove inactive volumes to use the disk
I have Netgear readyness 428. From last few days it is showing remove inactive volume 123456 to use the disk, Netgear technical team not giving any support because product is no longer supported. Ther...
Marc_V
May 20, 2022NETGEAR Employee Retired
Welcome to the Community!
I believe I have answered another post you have about this issue. If your NAS is registered on your myNETGEAR account I would strongly advise that you create an online case so they will be able to support and assist you with the volume offline concern.
You can go to my.netgear.com to do so.
HTH
AHPL
Netgear technical team not doing any help, My product is under warranty & support license has been expired, When I am renewing my support license it is showing this product is not supported. I have called customer care no. they are saying I can't help you because this issue is related to L3 support & not transferring my issue to technical support. My data is crucial & I am just hopeless from Netgear.
Please help.
