Paulaus
Oct 16, 2023Aspirant
remove inactive volumes to use the disk
the system overview shows status healthy. when I click on each disk they are all disk state omline. disk 3 has 28k+ errors, the other disks 0 I was running raid 5 I have not accessed or used for m...
wjdreamin
Apr 21, 2024Aspirant
Could sure use some help similar to this other person. Removed all drives, was able to reformat one because the other 3 had these same error messages but then when I shut down, went to bed, rebooted and reinstalled the drives I have the "inactive" message but all 3 of them have data! My data! the data I desperately need to save. I've downloaded a log. Would appreciate any help in getting these to load at least long enough that I can get my data. Thank you!
- StephenBApr 21, 2024Guru - Experienced User
Reformatting was a mistake.
wjdreamin wrote:
Could sure use some help similar to this other person. I've downloaded a log. Would appreciate any help
If you want me to take a look at the log zip file, then upload it to cloud storage (dropbox, google drive, etc), and send me a private message (PM) using the envelope link in the upper right hand corner of the forum page. Include a link to the logs in the PM. Make sure the link permissions are set to allow anyone with the link to download.
