Eric23
Feb 20, 2022Aspirant
Replace disk after RAID 1 rebuilt / readyNAS 102
Hello,
I had set up a RAID 1 type assembly with 2 disks and made a backup on a 3rd disk by synchronizing it via RAID 1. Today, I broke / rebuilt the RAID 1 and formatted the 2 disks. I want to s...
Eric23
I did destroy the RAID 1 volume, switch off the NAS, put inside the 3rd disk but when I switch on the NAS, the password isn't recognised.
Do you have any idea why ?
Thanks again fir your help
Feb 20, 2022Guru - Experienced User
Are you using the same password you were using when you created the disk?
The credentials (like everything else) is on the disk, not saved in the NAS itself.
