Eric23
Feb 20, 2022Aspirant
Replace disk after RAID 1 rebuilt / readyNAS 102
Hello,
I had set up a RAID 1 type assembly with 2 disks and made a backup on a 3rd disk by synchronizing it via RAID 1. Today, I broke / rebuilt the RAID 1 and formatted the 2 disks. I want to s...
Feb 20, 2022Guru - Experienced User
Eric23 wrote:
I did destroy the RAID 1 volume, switch off the NAS, put inside the 3rd disk but when I switch on the NAS, the password isn't recognised.
Do you have any idea why ?
Thanks again fir your help
Are you using the same password you were using when you created the disk?
The credentials (like everything else) is on the disk, not saved in the NAS itself.
Eric23
You're probably right...the password is not the same so I will try the others I put at the time I created this disk and let you know if it's ok.
Many thanks again for your help
