Gilfammedicine
Mar 01, 2019Aspirant
Restricting folders with Passwords
Ok, i have fixed many of the issues i have come up with so far. My only issue now is that i need to setup accounts so that users can only access certain files. This is the setup i need:
Admin a...
Mar 02, 2019Guru - Experienced User
Gilfammedicine wrote:
I have created these users but when i map the drives, it doesn't request credentials.
This is more about Windows than the ReadyNAS.
You can create credentials in the Windows Credential Manager for the NAS (one for the hostname and potentially one for the ip address). You can enter the password there too if you want the access to be automatic, but you can also leave it out.
You can also specify the credentials when you map the drives.
Also, generally it works out better if you leave "file access" set to everyone, and manage access with "network access".
- GilfammedicineMar 04, 2019Aspirant
Thanks for the reply!
I had already entered the credentials in Credential Manager, but everyone still has access to each file regardless of their credentials. You think I need two credentials you said? One for the IP and one for the hostname? I only created the credentials for the IP. I'll try adding another one.
- StephenBMar 04, 2019Guru - Experienced User
Gilfammedicine wrote:I had already entered the credentials in Credential Manager, but everyone still has access to each file regardless of their credentials.
Are you setting network access permissions or file access permissions in the NAS? You should be using network access permissions.
Also, in order to test network access you need to clear out any open sessions in the PC. You can do this by rebooting, or by running CMD and entering net use * /delete
That depends how people access the NAS. If people use the IP address, then you need a credential for that. If they use hostname, then you'll need a second one.
