MartinEb
Jan 28, 2021Guide
Reuse of old ReadyNAS formatted disks
I recently upraded my disks from 4 TB to 8 TB models to have more space on the drive. When I try to use the old 4 TB drives as normal external USB drives, I see only 1.8 TB of disk size. Where ...
- Jan 28, 2021
Martin,
Erase the partitions of these HDDs on a "generic" Linux system (careful, use the correct physical device name!), like...
dd if=/dev/zero of=/dev/sdz bs=512 count=1
...or use the Windows disk manager to drop any existing partitions.
If this does not mitigate, it's well possible you use compareably old USB enclosures which are limited to 2 TB storage block devices only.
-Kurt
Sandshark
Jan 28, 2021Sensei
My guess is an enclosure limited to 2TB drives. A Windows machine normally doesn't see a NAS formatted drive at all except in Disk Manager. If it does show as 1.8TB in Disk Manager, then the issue is the enclosure.
MartinEb
Feb 01, 2021Guide
Thanks for the tip!
I thing that my enclosure is outdated. I try to organise an new enclosure, that supports more than just 2 GB drives.
regards
Martin
