tonyaa's avatar
tonyaa
Tutor
Sep 06, 2020
RN104 failed disk exchange issue
Hi all! I have a RN104 equipped with 3 HDD: 1x2TB and two 4TB.  Few days ago, just after moving to a new apartment, I've got a messagem that volume status on my RN104 is degraded. After logs downl...
  • Sandshark's avatar
    Sandshark
    Sep 10, 2020
    Drive 2 is reporting a temperature of 0 and no SMART data.  That could indicate the drive is simply spun down, but I don't know why it would do that.  So another possibility is the drive is bad.  It is missing from your data array, as you stated.
    Connecting the drive to a PC and testing it with SeaTools is your best next step.  If it passes, then see if there is existing partitioning.  If there is, try removing that and re-insert the drive (with power on).
ProSupport for Business
