77PALE77
May 05, 2023Apprentice
RN104 Plex not installing on OS 6
Hi everybody, some years ago I had Plex installed on my ReadyNAS RN104, then I removed it. Now I don't even find it in the available apps, but if I go on Plex website I can download the installer f...
77PALE77
Thanks a lot,
I’m not skilled in installing via ssh…
Now I am hosting Plex Media on a Mac and pointing to the desired share on NAS as you wrote. But I do not want to keep this Mac always on…
DLNA is already turned on on the share, and this is the way I have used until now, but if I change device during a movie, I have to start it from the beginning and then go to the correct timing manually. Plex would solve this…
Maybe I don’t understand if you mean something different than this.
May 05, 2023Guru - Experienced User
Got that. But hosting it on a Mac (or a Window or Linux PC) is IMO your best option. The RN100 series has very little memory and a rather slow CPU. Installation is also complicated by the deprecation of Debian 8 (Jessie).
- 77PALE77May 06, 2023ApprenticeSurely you are right, I have no other better idea than this. Maybe I will change my NAS but for now I will keep this config.
Thanks again!
