david_spittle
Apr 12, 2022Tutor
RN314 - OS partition full?
Hi I went to log into my NAS admin page and it didn't work, just went into a loop asking again for my credentials. I tried to SSH in via putty, and also windows: ssh root@ip-address. Access ...
Apr 12, 2022Guru - Experienced User
If you don't have a backup of your data, then considering doing that before anything else.
Perhaps try downloading the logs from RAIDar next: https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
It is possible to get into the NAS via tech support mode, and then mount and explore the OS partition. But if you can get the logs first, then we'd know if the OS partition was full (or if you are dealing with something else).
Was ssh enabled in system->services?
david_spittle
Apr 12, 2022Tutor
Hi
I managed to log in using Terminal. ssh root@ IP
Any ideas what to type from here to figure it out?
Thanks
***edit*** I got a bit excited when I finally managed to access. I've DLed Raidar and will download the logs, it's very slow, but perhaps it will be done by the morning...
