Jaybone512
Jan 18, 2021Aspirant
RN314 Front Panel - Null ffffffff880fa4cf
Hi, all. I've got a RN314 that's started showing "(null)+ffffffff880fa4cf" on the front panel. Currently running 6.10.1. The logs aren't showing any errors or warning, status on everything looks g...
- Jan 19, 2021
Pull a fresh log-gather from the cluster ("System" > "Logs" > "Download Logs") and look for the files there.
Jaybone512
IPv6 is already disabled, actually.
nsne
Jan 18, 2021Virtuoso
Huh. Well, now I don't know what to think. When I came across this before, I recall being told it was down to IPv6.
At any rate, did a reboot solve it?
- mdgmJan 18, 2021Virtuoso
From memory, I think "null" doesn't tell you a lot about the error. You'd need to check the logs or if not in there monitor the serial console to get more information.
The LCD only shows a snippet of the kernel error message. The full error message (several lines) should be in kernel.log and systemd-journal.log if it has not already been rotated out.
- StephenBJan 19, 2021Guru - Experienced User
Agreed. I suspect it's just indicating that a null pointer was de-referenced somewhere. Definitely worth looking for the error in the logs.
- Jaybone512Jan 19, 2021Aspirant
mdgm wrote:From memory, I think "null" doesn't tell you a lot about the error. You'd need to check the logs or if not in there monitor the serial console to get more information.
Hi, thanks.
Where should those logfiles be found? I'm not seeing them anywhere.
root@RNfakeName:/# find . -name "*systemd-journal.lo*" root@RNfakeName:/# find . -name "*kernel.lo*" root@RNfakeName:/#
root@RNfakeName:/var/log# ls -clahsR *.log 132K -rw-r--r-- 1 root root 130K Dec 17 10:07 dpkg.log 4.0K -rw-r--r-- 1 root root 7 Jun 7 2016 LeafP2P.log 4.0K -rw-r--r-- 1 root root 2.9K Mar 12 2014 netatalk.log 4.0K -rw-r----- 1 root root 3.2K Nov 29 10:56 proftpd.log root@RNfakeName:/var/log#
- rn_enthusiastJan 19, 2021Virtuoso
