Printelf
Jun 14, 2014Aspirant
rn314 memory upgrade?
Hello I have a RN314 with the standard 2gb ram I was wondering if anybody has upgraded the ram to 4gb? Did it work? I am having some sluggish syncing going on and figured the ram would help. I upgr...
ReadyJabba
Dec 27, 2014Tutor
I have my 312 hooked up to a panasonic TV via HDMI right now without issue, running the memory test. Maybe you need to toggle the TVs input to suit the hdmi port you are using?
