droz1
Feb 17, 2015Aspirant
RN316 Memory upgrade?
I've looked around and didn't see any posts about this. Is it possible and I'm guessing maybe uses the same memory as the 314? Thanks
CLHatch
Jun 03, 2015Luminary
mdgm wrote: Yes.
The 312, 314 and 316 all use the same CPU and RAM.
Note that we don't support 3rd party memory upgrades. If you do upgrade the memory be sure to run the memory test for at least a few passes before trusting the memory. Note: it is possible that incompatible memory may pass the memory test.
Been looking for the "recommended" memory for the 316... I know it's not "officially supported," but what is a good memory module for it? I have a 316 on the way, and depending on performance, I might upgrade the memory in it later. At the very least, what voltage and timings does it need?
