droz1
Feb 17, 2015Aspirant
RN316 Memory upgrade?
I've looked around and didn't see any posts about this. Is it possible and I'm guessing maybe uses the same memory as the 314? Thanks
mdgm-ntgr
Jun 03, 2015NETGEAR Employee Retired
Any performance boost from a memory upgrade wouldn't likely be that great unless you are doing things which are very memory hungry leading to lots of swapping.
You'd see a much greater performance boost from getting a 516.
