JHRR
Oct 01, 2021Aspirant
RN316 running drives at 3Gb/s
I have all 6Gb/s capable drives installed but they are all operating at the slower speed. Any clues what could be going on? Latest FW with three Seagate 16TB Ironwolf NAS drives and three WDC 8TB Red...
Sandshark
Oct 02, 2021Sensei
And you believe this why?
Do you have an eSATA device connected? The eSATA is only capable of 3Gb/s and while I don't think it slows the others down, maybe it does.
- JHRROct 02, 2021Aspirant
Thanks for the reply Sandshark. No, these are all the internal drives. No drives USB or eSATA connected externally at all.
- SandsharkOct 03, 2021Sensei
And the method you used to determine they are only at 3Gb/sec? Spinning platter drives are not capable of maintaing that rate, so timing a transfer won't tell you.
- schumakuOct 03, 2021Guru - Experienced User
This will return the negotiated SATA link speed:
root@RNxxxX:~# smartctl -a /dev/sda | grep "^SATA"
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
root@RNxxxX:~# smartctl -a /dev/sdb | grep "^SATA"
root@RNxxxX:~# smartctl -a /dev/sdc | grep "^SATA"
root@RNxxxX:~# smartctl -a /dev/sdd | grep "^SATA"
