wsirhcm
May 05, 2016Aspirant
rn316 with 4 x 6tb wd drives - getting error message 'out of memory. isra. 16+31c' #26833911
wsirhcm
May 06, 2016Aspirant
Hi All,
Thanks for your inputs. I will raise a support request as suggested. What is FW?
The model I have is a Ready Nas 6 bay 316, to which I added 4 red WD 6TB nas drives, which gave me circa 16TB of usable back up space. I wanted to back up my data and video library from my desktop PC which I copied across via the drag and drop process using readcloud. I had been sucessfully streaming videos to my Samsung Smart TV via the home network for several months. I assume the default TV apps provide the necessary codecs etc as I did not have to download any further apps to 'see' and 'play' video files from the nas via the home network.
(I had previously used PS3 media server installed on the PC to stream video files direct from the PC). I should mention that about 3-4 months ago I migrated to Windows 10 from Windows 7. The streaming of videos did not seem to be affected my this. However about 10 days ago I suddenly lost access to the nas on the network. On trying to open the nas folders via readycloud I got a nessage saying somthing like not available - I cant rememeber the exact message.
After all this happened I decided to wipe my PC main hd and reinstall Windows 7, as I realy cant stand Windows 10 any longer.
I got the note from netgear about readycloud merging with my netgear and the OS update but cant as yet do it untill I sort this ssue out.
May 06, 2016Guru - Experienced User
Are you using ReadyDLNA or Plex? Or are you accessing the videos with windows file sharing?
- mdgm-ntgrMay 11, 2016NETGEAR Employee Retired
FW is short for firmware
