JWolberg
Sep 01, 2020Aspirant
RN31600 Two drive failure within 30 minutes
Hello- I have a RN31600 running 6.10.3. I had a drive go bad about three weeks ago. I purchased a replacement and swapped it out. It rebuilt fine. See the log snip below: Aug 12, 2020 ...
JWolberg
Hi Marc-
I bought it in December of 2017 so I know it's not under warranty. I find it *highly* unlikely that both drives are actually dead. The chance of two drives going out within 30 minutes is pretty far fetched. Most likely it's just the first one that is having an issue.
Is there any way I can contact support prior to paying the $150 to at least see if it's something they can assist with? I'd hate to throw $150 away if they are just going to tell me to use a recovery software/vendor which I'd then have to pay again for.
Thanks.
JWolberg
I logged in via SSH since it's just Linux after all running software raid.
root@Homeshare:~# mdadm --detail /dev/md127
/dev/md127:
Version : 1.2
Creation Time : Thu Jan 4 08:52:28 2018
Raid Level : raid5
Array Size : 9743324160 (9291.96 GiB 9977.16 GB)
Used Dev Size : 1948664832 (1858.39 GiB 1995.43 GB)
Raid Devices : 6
Total Devices : 6
Persistence : Superblock is persistent
Update Time : Tue Sep 1 07:29:03 2020
State : clean, FAILED
Active Devices : 4
Working Devices : 4
Failed Devices : 2
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
Consistency Policy : unknown
Name : 2fe74df0:data-0 (local to host 2fe74df0)
UUID : eca418b9:8c6b97ab:ae67bc06:e44f2671
Events : 70945
Number Major Minor RaidDevice State
- 0 0 0 removed
- 0 0 1 removed
2 8 35 2 active sync /dev/sdc3
6 8 51 3 active sync /dev/sdd3
4 8 67 4 active sync /dev/sde3
5 8 83 5 active sync /dev/sdf3
0 8 3 - faulty /dev/sda3
1 8 19 - faulty /dev/sdb3
The array looks to be clean but obviously in a failed state. I don't believe both drives are actually bad though. I believe I should be able to bring it back with a "mdadm --assemble /dev/md127 --scan". Has anyone ever done this before?
- JWolbergSep 01, 2020Aspirant
Just to keep people updated....
I tried to manually re-mount the drives through the CLI and nothing showed up. I then reseated them one at a time. Both drives made a clicking/beeping noise. The beeping is the spindle motor trying to start up either because it doesn't have enough power to do so or is running into something, hence the clicking. To rule out power I powered off the NAS and swapped the ports with other good drives.
The clicking/beeping followed the bad drives, so it sounds like both of them decided to go bad within 30 minutes of each other for no reason. Best option at this point is data recovery services....
