TOM2806
Jun 10, 2019Aspirant
RN516 stuck at WELCOME
After loading of the new firmware my system "rebooted" and stucked at once at the Welcome message. Ok I decided to accept to loose all my data and wanted to make a reboot via the RESET button on the ...
Jun 10, 2019Guru - Experienced User
The process is described on pages 120-121 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
If you do manage to trigger it, I suggest trying the OS reinstall first - it has worked for some folks, and it would preserve your data.
TOM2806 wrote:
Do I have to throw away my RN516?
Hopefully not. One option is to connect one of the disksto a Windows PC and zero it (either using Seatools or WD's Lifeguard program). Then power up the NAS with only the blank disk installed. It should do a factory install automatically. If that works, zero the remaining disks and add them to the array. If your disks are different sizes, then start with the smallest one.
- TOM2806Jun 10, 2019Aspirant
Dear Stephen,
thanks for your fast reply. Of course I did all this actions like discribed on page 120 and 121. I even pressed the reset button more than 30 min without any result. Now I will try your proposal with the "zero" disk. Hopefully this will work. I will keep you posted.
- StephenBJun 10, 2019Guru - Experienced User
Sometimes the reset button does break, so you should also check your warranty status (5 years for the original purchaser).
Hi Stephen,
I tried the solution wth the "Zero" Disk. Unfortunately system remains also at the welcome message.
Yes it migth be that the reset button is broken internally even I have the feeling hat i still can push him. And bad luck - my waranty is over since I bought the system in May 2014. Seems I am in deep **bleep** now. Any other idea? Thanks for your effort
