TOM2806
Jun 10, 2019Aspirant
RN516 stuck at WELCOME
After loading of the new firmware my system "rebooted" and stucked at once at the Welcome message. Ok I decided to accept to loose all my data and wanted to make a reboot via the RESET button on the ...
TOM2806
Dear Stephen,
thanks for your fast reply. Of course I did all this actions like discribed on page 120 and 121. I even pressed the reset button more than 30 min without any result. Now I will try your proposal with the "zero" disk. Hopefully this will work. I will keep you posted.
Jun 10, 2019Guru - Experienced User
Sometimes the reset button does break, so you should also check your warranty status (5 years for the original purchaser).
- TOM2806Jun 10, 2019Aspirant
Hi Stephen,
I tried the solution wth the "Zero" Disk. Unfortunately system remains also at the welcome message.
Yes it migth be that the reset button is broken internally even I have the feeling hat i still can push him. And bad luck - my waranty is over since I bought the system in May 2014. Seems I am in deep **bleep** now. Any other idea? Thanks for your effort
- StephenBJun 10, 2019Guru - Experienced User
TOM2806 wrote:I tried the solution wth the "Zero" Disk. Unfortunately system remains also at the welcome message.
Perhaps try again, and see what status RAIDar gives you.https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
Note that a zeroed/blank disk is NOT the same as a reformatted disk.
