TOM2806
Jun 10, 2019Aspirant
RN516 stuck at WELCOME
After loading of the new firmware my system "rebooted" and stucked at once at the Welcome message. Ok I decided to accept to loose all my data and wanted to make a reboot via the RESET button on the ...
zero101a
Jun 11, 2019Tutor
Hi there,
I have a RN516 exhibiting the same symptom’s as yours. Stuck on Welcome with Fans at full speed. Inaccessible from RAIDar, and cannot even see a boot screen by plugging in keyboard and monitor.
Mine is well out of warranty, so is a door stop at the moment.
As far as I can work out the problem is a corruption of the onboard BIOS chip.
Netgear cannot (will not) help with out of warranty hardware issues.
I did see a post on a Polish forum, where someone managed to copy the firmware from a working RN516 and copy it via a programmer over the faulty chip.
This took a great leap of faith that they wouldn’t kill the good unit in the process.
Good luck in your endeavours to fix yours.
- TOM2806Jun 16, 2019Aspirant
Dear community,
thanks for you try to help me with my ReadyNAS. Since it is out of warranty and I have no chance to use it anymore it is time to forget about Netgear. So I will waste my ReadyNAS Pro 6 and ReadyNAS 516 and will switch to QNAP. Thanks for your collaboration, maybe we will meet each other in the forum of the famous competitor. Wish you luck with your NAS and hopefully your box will not stop after 5 year and 1 month like mine. Thanks again
