dunkens
Jan 13, 2021Apprentice
rn526 cant access it via admin anymore
Hi Did a upgrade to 6.10.4 and rebooted I can see it appears in the switch ang gets ip , but i cant reach the nas at all dosent responds to ping , did a second restart of the nas , same thin...
Jan 13, 2021Guru - Experienced User
- Are you saying that you can't reach the admin page, or that you can't access the shares in Windows Explorer/Finder (or both)?
- What status are you seeing on the LCD?
Have you tried installing RAIDar? It might give you more status information. https://kb.netgear.com/20684/ReadyNAS-Downloads
- dunkensJan 13, 2021Apprentice
Hi
Couldnt access it at all ...
Did found a way , did remove the network cable and inserted it again , then it did work
Wierd , but it works :)
Never had any issues before with upgrading the nas
- SandsharkJan 14, 2021Sensei
Is it possible that something else on the network was assigned the same IP address? How is your NAS IP address assigned, DHCP (with or without address reservation in the router) or static?
- dunkensJan 14, 2021Apprentice
Hi
Nas is using static ip , it feels like the nic interface went hayway somehow ..
But glad its working as it should :))
