dunkens
Jan 13, 2021Apprentice
rn526 cant access it via admin anymore
Hi Did a upgrade to 6.10.4 and rebooted I can see it appears in the switch ang gets ip , but i cant reach the nas at all dosent responds to ping , did a second restart of the nas , same thin...
dunkens
Hi
Couldnt access it at all ...
Did found a way , did remove the network cable and inserted it again , then it did work
Wierd , but it works :)
Never had any issues before with upgrading the nas
Sandshark
Jan 14, 2021Sensei
Is it possible that something else on the network was assigned the same IP address? How is your NAS IP address assigned, DHCP (with or without address reservation in the router) or static?
- dunkensJan 14, 2021Apprentice
Hi
Nas is using static ip , it feels like the nic interface went hayway somehow ..
But glad its working as it should :))
- SandsharkJan 15, 2021Sensei
If you are using a static IP (which is not really the best way to do it), make sure that address is outside the range of assignments by DHCP or that you also reserve it in the router (which negates the need for the static IP). Otherwise, the router might assign that address to another device as well if the NAS is off at the time, and the NAS will not communicate properly.
Address reservation in the router is typically a better way to go. That way, if you change routers and the new one uses a different subnet from the old, you don't have to figure out how to get into the NAS GUI to change it's address.
