jimk1963
Jan 16, 2023Virtuoso
RN528 - how to determine RAM config
Found this post: https://community.netgear.com/t5/New-ReadyNAS-Users-General/528x-ram-memory-upgrades/m-p/1410735 User runs "hwinfo" and "dmidecode" to determine his RN528 RAM config. I've o...
Jan 16, 2023Guru - Experienced User
You don't need sudo, since you are logging in as root.
You can install dmidecode if you like with
apt-get install dmidecode
My RN526x has one DIMM module installed.
root@NAS:~# dmidecode --type 17
# dmidecode 2.12
SMBIOS 3.0 present.
# SMBIOS implementations newer than version 2.8 are not
# fully supported by this version of dmidecode.
Handle 0x005B, DMI type 17, 40 bytes
Memory Device
Array Handle: 0x0059
Error Information Handle: Not Provided
Total Width: 72 bits
Data Width: 72 bits
Form Factor: DIMM
Set: None
Locator: DIMM_A1
Bank Locator: NODE 1
Type: Other
Type Detail: Synchronous
Speed: 2133 MHz
Manufacturer: Undefined
Serial Number: 0013EAFE
Asset Tag: DIMM_A1_AssetTag
Part Number: TS512MLH72V1H
Rank: 1
Configured Clock Speed: 1866 MHz
Minimum voltage: Unknown
Maximum voltage: Unknown
Configured voltage: 0.003 V
Googling the part number indicates this is a Transcend part - DDR4 ECC Long-DIMM 4 GB
