monica985
Aug 10, 2019Aspirant
RND 2000 V2 Ready NAS DUO Wrong IP address
Ok everybody - Here is my delima. I changed cable providers, the first used 10.x.x.x as it's addy's. Months later I plug in the Duo AND no access. Raidar (firmware 4.1.7) tells me both drives are he...
monica985
Aug 12, 2019Aspirant
Hi Stephen! Thank you for your help and suggestions. In reading through the manual that you posted. I intentionally didn't use
that one because it calls for a "status display screen". NOT on this DUO, if it's refering to Raidar, not there either. I will try your other
suggstions later.. Monica
Sandshark
Aug 12, 2019Sensei
RAIDar is a program you download here, so it definately is available to you. The manual refers to RAIDar version 4.x, which is still available and better to use with the legacy products such as yours than the newer RAIDar V6.x. Just Google it to find the download link.
- StephenBAug 12, 2019Guru - Experienced User
It's here: https://kb.netgear.com/20684/ReadyNAS-Downloads
Though you won't need it for this.
that one because it calls for a "status display screen".Then you didn't read it carefully enough. The manual covers both the NV+ (which has an LCD status display) and the Duo (which doesn't). The pages I gave you in the first post were for the Duo, and those instructions don't refer to the status display.
