andy_f
Oct 31, 2015Aspirant
RND2000-100NAS fail
After several years my RND2000-100NAS appears to have failed. Yesterday I could not access it and found it was completely dark, no lights. It would not power up. I verified AC power was good and veri...
- Oct 31, 2015
if you are using xraid, you can get the data off using linux reader-connecting the data drive to a windows PC (http://www.diskinternals.com/linux-reader/)
Usually the data disk is in slot 1 (leftmost) and the parity disk is in disk 2. So try disk 1 first. If you don't see the data volume, then try disk 2.
andy_f
Nov 01, 2015Aspirant
Thank you very much Stephen! I installed the software you recommended, removed the drive from slot 1 of the ReadyNAS, put it in an external drive enclosure, and was able to recover almost all of my files. My backup files are unrecoverable for some reason but it appears I was able to recover all other files.
Your advice was a lifesaver, thank you very much. Based on this experience I will no longer store irreplaceable data on a ReadyNAS. The redundancy of RAID protects against hard drive failure but I hadn't considered that failure of the ReadyNAS unit itself would result in a situation where I am dependent on 3rd party freeware that may or may not be able to recover my data.
Thanks much for the help Stephen!
mdgm-ntgr
Nov 01, 2015NETGEAR Employee Retired
You shouldn't store irreplaceable data on any single device, no matter what that device is.
Backups are vital.
