gper56
Apr 27, 2022Aspirant
RND4000 Stuck at 13% when booting
Hi The device is out of warranty. Serial number 23J5197M00AFE So far I have attempted testing drive to see if that gets any results. They all appear to be good. I have reinstalled the OS - still ...
- May 14, 2022
Eventually got to the Factory reset stage.
This worked but disk 2 showed as failed which may have been the problem all along but no other evidence.
Replaced the disk a did another Factory reset and all came back golden. 🙂
Did full Shutdown restart to find that disk 2 reported as dead. 😞
tried a couple of other disks in Slot 2. They also reported dead. Beginning to suspect that Slot 2 is faulty.
Tried another disk and it is now syncing.
I think that slot two may be playing up so will see how it goes with the thought that is has gone past its best and needs replacing.
Apr 27, 2022Guru - Experienced User
gper56 wrote:
I have had to use an old Win7 Machine to get to the Web interface and have been able to download the System Logs but they do not make much sense to me. It is a ZIP file so will not upload 😞
Which is a good thing, since there is some privacy leakage (so the full log zip shouldn't be shared publicly).
What you can do is ask the mods ( Mark_V and JeraldM ) if they are willing to take look at them. If they are, you can upload the full zip to cloud storage (google drive, icloud, dropbox, etc), and send them a download link using the private message (PM). You can send a PM using the envelope icon in the upper right of the forum page.
Is your NAS is running 4.1.x firmware? Or is it running 5.3.x?
gper56
Apr 28, 2022Aspirant
Thanks for the reply.
As far as I know it is V4.?
I will PM the Mods to see what they can suggest.
- StephenBApr 28, 2022Guru - Experienced User
Look for raidiator_version.log in the log zip file. If it's there, then open it - it will include the firmware version.
For example, my own NV+ has this:
RAIDiator!!version=4.1.16,time=1495530915- gper56Apr 29, 2022Aspirant
- StephenBApr 29, 2022Guru - Experienced User
Thx. So 4.1.x firmware - with the final firmware (4.1.16) installed.
If you want to check OS partition usage, you can open up disk_usage.log The first line under the title shows the OS (root) partition. My own system shows this:
Filesystem Size Used Avail Use% Mounted on /dev/hdc1 2.0G 365M 1.6G 19% /
