nortonuser's avatar
nortonuser
Follower
Apr 21, 2024
RNDP 2220 password
I forgot my password on READYNAS RNDP 2220 can any one help please. ?
1 Reply
  • StephenB's avatar
    Do an OS reinstall using the instructions on pages 15-16 of the hardware manual:
    If your NAS is running 4.2.x firmware, then
    • the admin password will be reset to "netgear1"
    • the network configuration will be set to DHCP with no bonding
    If your NAS has been converted to run OS-6 firmware then
    • the admin password will be reset to "password"
    • the network configuration will be reset to DHCP with no bonding
    • volume quota will be disabled (it can be re-enabled using the volume settings wheel).
ProSupport for Business
