studdsit
Aug 20, 2021Aspirant
RR4312X0v2 - Backup failing via RSYNC
Trying to do backup from RR4312X0v2 with firmware 6.10.1 of a folder using RSYNC to RR4312X0v2 getting this error, what to do
Backup Job Name: Brand_Registrations
Backup Job Type: Incremental
Protocol: rsync
Backup Source: [Brand_Registrations]/
Backup Destination: [remote:rsync]/192.168.4.19::CommonNas-Brand-Registrations
Backup Start Time: Fri Aug 20 2021 10:08:23 PM
Backup Finish Time: Fri Aug 20 2021 10:08:24 PM
Backup Status: Fail: Failure during copy.
Failed to run rsync, return rc 10
sending incremental file list
rsync: read error: Connection reset by peer (104)
rsync error: error in socket IO (code 10) at io.c(794) [sender=3.1.3]
Is the rsync daemon running on the remote server?
There might be more information in the log zip (or equivalent on the destination). You might look in dmesg.log first.
- SandsharkSensei
My first suspicion would be that you didn't set up rsync write capability on the receiving NAS share.
- studdsitAspirant
Thanks for the suggestion, can you help me on this anything particular I should check as I have setup write but only thing I suspect is on folders where backup is working fine
folder owner is number like - 32768 and group is like - 32773 but where its failing folder owner is saladmin and folder group is domain admins...not able to understand how this numbers came in the NAS
- studdsitAspirant
RSYNC Daemon is running
