jlazkano
Dec 23, 2021Aspirant
Rsync over Remote SSH backup
Hello, I have RN104 NAS working great. I had configured a Rsync over Remote SSH backup some month ago. The remote server is Debian machine and the "Test Connection" sais it is OK. Now, I ...
- Dec 23, 2021
Are you are backing up the full data volume in one backup job?
If you are, then go into the advanced settings in the backup job. Check the box next to "Multiple File Systems". That should solve the problem.
Dec 23, 2021Guru - Experienced User
jlazkano
Dec 24, 2021Aspirant
Thank you!!!
It solve my problem.
Kind regards.
