Aus_Murph's avatar
Aus_Murph
Follower
Nov 17, 2016
Running Nakivo Backup on ReadyNAS
G'day All,
I'm using a ReadyNAS for offsite backup storage of data from Nakivo Backup software.  I've found from previous experience that Nakivo seems to work better if the remote site has its own transporter, so I'm toying with installing the transporter software on the ReadyNAS device, as there are no servers at the site, only the NAS.  Nakivo transporter can be installed on Linux and is also supported on Synology NAS units, so theoretically it should be possible on ReadyNAS.
Has anyone previously attempted, or had any experience attempting to undertake similar operations?
What are the pitfalls I need to watch for?
If it all goes peaar shaped, how do I recover the NAS unit?
Thanks, in advance for any feedback.
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello Aus_Murph,
    Welcome to the community!
    Apps that are available for ReadyNAS can be checked here.
    If it is not listed and you have not found it from the community apps board, adding this as a suggestion at the idea exchange board may help.
  • JennC's avatar
    JennC
    Hello Aus_Murph,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
    The Netgear community looks forward to hearing from you and being a helpful resource in the future!
