Digsy's avatar
Digsy
Samba share access permissions not making sense
I just noticed that access permissions for SMB shares on my ReadyNAS102 don't seem to be working.   When I set up my RN102 sereval years ago I was a bit lazy and just set up all my shares as read/w...
  • StephenB's avatar
    Sep 21, 2020
    Digsy wrote:
    The CCTV share is the only share that I want to require a username and password for, but when specify this username in Network Access and I supply credentials for it when I try to connect, it doesn't work unless I use the command line.Windows won't accept my username and password as valid, but the command line will.
    Obviously this is a Windows issue.
    If you entered the credential in the Windows Credential Manager, then you shouldn't be needing to enter the username at all.  If you also entered the password there, you shouldn't be needing to enter that either.
    Are you entering \\nas-ip-address\sharename in the file explorer address bar to access the share?
    One thing to keep in mind - Windows only allows one set of credentials per machine at a time.  And if you first access the NAS w/o a credential, Windows will still use one - it defaults to using the Windows Login.  You can clear that using the net use * /delete /y command.  So perhaps just try that command, and then see if the file explorer will take your credential.
ProSupport for Business
