jimk1963
Mar 06, 2024Virtuoso
SATA SSD's - Are Disk Scrub and Disk Test necessary?
RN528X, freshly repopulated with 8 Crucial 4TB MX500 SATA SSD's. With guidance from StephenB , I set up the NAS to perform each of the 4 Maintenance tasks once per quarter (Scrub, Disk Test, Def...
Mar 07, 2024Guru - Experienced User
With guidance from StephenB , I set up the NAS to perform each of the 4 Maintenance tasks once per quarter (Scrub, Disk Test, Defrag, Balance). This was with spinning HDD's initially.
Question: with SATA SSD's, is it advisable or not advisable to run all 4 of these maintenance tasks on this schedule?
is there anything "electromechanical" about the HDD's that makes them need these tests but SSD's do not?
Getting back to the main questions:
- Defrag has marginal value even with mechanical disks. SSDs have 0 seek time, so you could just turn this off. You can always run it manually.
- I'd run the disk test, as it doesn't effect endurance.
- Balance reclaims/consolidates optimizes BTRFS free space. It will do some writes, but I'd run it anyway. On my systems, it usually completes in less than 45 minutes.
- Scrub is the unknown. If it does rewrite all the parity blocks (which would be the worst case), then you'd be writing 25% of each disk with RAID-6, and 12.5% of each disk with RAID-5. Assuming RAID-6, you'd be writing 1 TB per drive every time you run it. The endurance rating for the MX500 4 TB model is 1000 TB. Overall the effect is relatively small (less than 0.4% reduction in disk life per year). I'd probably choose to run it, but I guess you could reduce the frequency.
