Kstaylor
Jun 11, 2023Aspirant
Saving files from iCloud to Readynas R31400
I am hoping someone can advise me please. I have a new iPad Pro and can connect to the NAS R31400 and read files but I am getting an error when I try to save or copy a file from iCLoud to the NAS. ...
schumaku
Jun 12, 2023Guru - Experienced User
For the non-informed reader: How do you connect from the iPad Pro to the ReadyNAS 314 share(d) folder?
Connecting as a registered user (with username nd password), and are the access rights set for this user accordingly?
- KstaylorJun 12, 2023AspirantHi, yes I logged into the nas using my registered user and password.
I can read a file from the nas but can’t save, share or copy a file to the nas from my iPad pro- schumakuJun 12, 2023Guru - Experienced UserIs it possible you need to be invited or allowed to access (read or work on) before you are able to download or copy anything?
The people you invite can download the shared items from iCloud to any of their devices, where they can view them and — depending on the privileges you set — collaborate.
https://support.apple.com/en-ie/guide/mac-help/mchl91854a7a/mac- KstaylorJun 13, 2023AspirantThank you for this suggestion. I will give it a try tonight and report back!!
Thank you
- StephenBJun 13, 2023Guru - Experienced User
Kstaylor wrote:
I can read a file from the nas but can’t save, share or copy a file to the nas from my iPad proIs this only with files stored in iCloud? or are you talking about files stored directly on the iPad?
If the latter, then it sounds like a permission problem on the NAS share.
When you say "registered user"- do you mean a local NAS user account?
Are you using ReadyCloud? (If so, you need to shift off that quickly, as Netgear is about to take it down).
- KstaylorJun 13, 2023AspirantHi, I created a pdf file from an email and saved it to iCloud. I also tried to save it the NAS but it gave me an error. I then tried to copy the pdf to the NAS and it gave me error 100093. Please see attachment.
I am logged onto the NAS as the local registered user.
Thanks for the tip about Readycloud I did see that. Any advice on an alternative?
Thanks
