miogpsrocks
May 29, 2020Tutor
Saving Raw Image on each Hard drive using Reclaime size of entire array vs size of actual drive.
Hello. I am trying to use a software called Reclaime to recovery from possible a hardware failture in a readynas. I don't have enough free ports to just plug in every hard drive so I was go...
May 30, 2020Guru - Experienced User
miogpsrocks wrote:
I am trying to use a software called Reclaime to recovery from possible a hardware failure in a readynas.
I don't have enough free ports to just plug in every hard drive so I was going to create an image file for each hard drive and run the recovery software.
For example, the process was 20% complete and the size of the file is 7.2TB(and growing) on a 8TB drive.
When the process was 26% complete, the file size was 9.56 TB( and growing)
Probably best to contact ReclaiMe support on this.
Glancing at the documentation, it appears to support both disk images and array images. It is possible that you went down the array image path.
