SR2017's avatar
SR2017
Scheduling file deletion
Absolute beginner with no NAS experience.  I have a sql maintenance plan backing up data from the sql server to a share on the NAS.   I need to create a clean up routine to delete files older than 3 days.  How do you do automated tasks ?
  • StephenB's avatar
    There's no way to automate file deletion.
    What you can do is schedule a daily backup - either use incremental rsync (set to delete files not on the source) or another protocol (full backup, set to delete all files in the destination share).  Either way will work, incremental rsync is more efficient.
    Then set up custom snapshots on the share with three days retention.
    The result will be that the main share will have just the most recent backup, but you can still get back the previous day's backups by restoring the snapshots.
    • SR2017's avatar
      SR2017
      Thank You StephenB. I have a lot to learn. I'll put this solution in place.
      • Sandshark's avatar
        Sandshark
        Sensei
        It certainly should be possible to set up a cron job that uses the find command to delete files older than some amount, but that can't be done via the GUI and is not somethng I'd recommend a beginner try his hand at.  A robocopy command on a Windows machine would be yet another way to do it.  Using an rsync copy is the most straightforward method do-able via the GUI and strictly running on the NAS.
ProSupport for Business
