aks-2
Aug 17, 2023Apprentice
Scrub started/completed and no other messages
I completed a scrub today on a RN214, and the log looks pretty sparse: 17 Aug 2023 19:11:40 Volume: Scrub completed for volume data'. 16 Aug 2023 14:46:03 Volume: Scrub started for volume data. ...
Aug 17, 2023Guru - Experienced User
aks-2 wrote:
Can I assume the absence of any other messages means there were no errors at all?
Your info is what I also see, and I do generally interpret that as meaning there were no issues.
You could look in the log zip to see if there were any btrfs errors or disk errors reported there.
- aks-2Aug 18, 2023Apprentice
btrfs.log appears clean - no errors.
I jumped in to systemd-journal.log and searched 'scrub' - here is a snippet:
Aug 16 14:46:04 NETDISK4 readynasd[2239]: scrub started on /data, fsid ** replaced ** (pid=18925)
Aug 16 14:46:03 NETDISK4 readynasd[2239]: Scrub started for volume data.
Aug 16 14:46:06 NETDISK4 msmtpq[18950]: mail for ** replaced ** : send was successful
Aug 16 14:47:22 NETDISK4 connmand[2127]: ntp: adjust (slew): -0.002244 sec
Aug 16 14:49:36 NETDISK4 kernel: BTRFS warning (device md124): i/o error at logical 7526547456 on dev /dev/md127, sector 16813824, root 278, inode 880, offset 734523392, length 4096, links 1 (path: Documents/ ** replaced ** 00037.MTS)
Aug 16 14:49:36 NETDISK4 kernel: BTRFS warning (device md124): i/o error at logical 7526285312 on dev /dev/md127, sector 16813312, root 278, inode 880, offset 734261248, length 4096, links 1 (path: Documents/ ** replaced ** 00037.MTS)
Aug 16 14:49:36 NETDISK4 kernel: BTRFS warning (device md124): i/o error at logical 7526023168 on dev /dev/md127, sector 16812800, root 278, inode 880, offset 733999104, length 4096, links 1 (path: Documents/ ** replaced ** 00037.MTS)
Aug 16 14:49:36 NETDISK4 kernel: BTRFS warning (device md124): i/o error at logical 7525761024 on dev /dev/md127, sector 16812288, root 278, inode 880, offset 733736960, length 4096, links 1 (path: Documents/ ** replaced ** 00037.MTS)
Aug 16 14:49:36 NETDISK4 kernel: BTRFS error (device md124): bdev /dev/md127 errs: wr 0, rd 1, flush 0, corrupt 0, gen 0
Aug 16 14:49:36 NETDISK4 kernel: BTRFS error (device md124): bdev /dev/md127 errs: wr 0, rd 2, flush 0, corrupt 0, gen 0
Aug 16 14:49:36 NETDISK4 kernel: BTRFS error (device md124): bdev /dev/md127 errs: wr 0, rd 3, flush 0, corrupt 0, gen 0
Aug 16 14:49:36 NETDISK4 kernel: BTRFS error (device md124): bdev /dev/md127 errs: wr 0, rd 4, flush 0, corrupt 0, gen 0
Aug 16 14:49:36 NETDISK4 kernel: BTRFS warning (device md124): i/o error at logical 7526809600 on dev /dev/md127, sector 16814336, root 278, inode 880, offset 734785536, length 4096, links 1 (path: Documents/ ** replaced ** 00037.MTS)
Aug 16 14:49:36 NETDISK4 kernel: BTRFS error (device md124): bdev /dev/md127 errs: wr 0, rd 5, flush 0, corrupt 0, gen 0
Aug 16 14:49:36 NETDISK4 kernel: ------------[ cut here ]------------That looks a bit worrying, albeit only a single file (0037.MTS) - which I could recover from a backup if it is in fact damaged. Should I interpret these entries as non-recoverable read errors?
- StephenBAug 18, 2023Guru - Experienced User
Personally I'd delete the file and restore it from the backup. Then re-run the scrub, and see if the problem disappears.
Though maybe also compare the backup copy with the one on the NAS. (Even if it matches, I'd delete the NAS copy).
Oh, I tried to copy that file to another area, that failed:
cp: error reading ' ** removed ** /00037.MTS': Input/output error
This is intriguing, no self recovery/error protection saved this file, RAID5 and BTRFS. My understanding is obviously incorrect. I will now dig out the backups and find that file.
How do I determine the type of failure, no disk errors are reported in the logs, this is a bit worrying to me as don't understand the cause behind the error. Any suggestions where I start to look?
