NASty1
Dec 22, 2017Aspirant
setting up joomla on rn31440
I am looking to set up a website (BLOG) on my rn314. I am new to linux, and was wondering if the version of joomla offered by netgear is necessary for operation, or whether I could install the newer...
- Dec 29, 2017
Hi NASty1
RN314 should be able to handle newer versions of the App. The unit has good specifications and handling those apps should not be a problem.
It will still be better to wait for advice from other Community members who have the same model and uses these apps.
Happy holidays!
Regards
Marc_V
Jan 01, 2018NETGEAR Employee Retired
Hi NASty1
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Aug 02, 2016Retired_Member
