GrahamCrafter
Jul 06, 2016Aspirant
Setting up my NAS for cloud access
I bought my NAS a while ago but did not populate it with disks or start to use it until recently (hence out of Netgear support). It is connected to my router and hence my PC and I have transferred fi...
GrahamCrafter
Raidar states I am using 6.5.0. I would have thought that I should have been told that I had to upgrade. If I upgrade, how is it done and will it affect my stored data?
As for your other question, I would not know. I have the device plugged in to my router and both the device and router are on 24/7.
GrahamCrafter
- StephenBJul 06, 2016Guru - Experienced User
There is a check-for-updates link next to the NAS firmware on https://192.168.1.191/admin Try clicking on that. The upgrade prompt appears as a popup, so if you have a popup blocker enabled in the browser, you should disable that for the NAS admin site,
- GrahamCrafterJul 06, 2016Aspirant
I cannot connect to https://192.168.1.191/admin even after re-starting my PC. I can still see my files through Windows.
What about my data? If I update firmware will/could I lose it. I am using a raid setup so one drive is the backup to the other.
What about my data?
Back it up. RAID is not enough to keep your data safe. Likely support could sort out your problem with the web admin interface without data loss, but that is not guaranteed.
