4xholic's avatar
4xholic
Setting up VPN on ReadyNAS with Mac
Hello All, I've had a ReadyNAS RN202 for a couple years and all appears to be ok except for setting up multiple remote users. I am trying to use softether so I can setup VPN connections to solve this issue, but I have a Mac. I've downloaded and installed the VPN Server App on the NAS but the launch button in not enabled. From another post, it appears the app does not have a web interface. After install, the vpnserver folder contains a file, but its ann EXE file. So... how can I launch the app? Anyone have luck with this? Are there other VPN options?
If any of you smat folk have any ideas, I would greatly appriciate some advice. Thanks.
1 Reply
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi 4xholic
    You may want to check this thread as it may help you with setting up a VPN connection with the NAS. Also, using ReadyCloud might be of interest to you since it also uses VPN connection.
    Regards
ProSupport for Business
